there should be an easier way to equip stuff
carston05100
PostSun Oct 11, 2015 4:05 am
I would love it if there was a way that aloud you to switch your armor/clothes with out having to open your inventory.
You should be able to click on the manikin and everything that is equipped will be put into and displayed on the manikin then when you equip something else then press it again it trades the displayed armor/clothes for what is currently equipped
(Want you to know I was using manikin as an example if you think of something better please tell me and I also want your opinion on this)
hunkyducky1
Re: there should be an easier way to equip stuff
PostTue Oct 13, 2015 8:05 am
The manikin idea is not bad but you would have to equip all the equipment that you want to put on the manikin which maybe more or less convenient than how it is done right now. Not really sure on how you switch equipment without opening inventory, maybe from the quickslots?
Molotov13
PostTue Oct 20, 2015 11:56 pm
If they made it so if you did a long press on an armor stand it will switch armor, I would definitely use that feature. Other then armor stands idk how else this would work
[GC: SladeMolotov13]
