New planet #3
New planet #3
PostThu Feb 25, 2016 3:54 pm
I cant think of a good planet name. The theme of the planet is an abandoned artificial planet.
All blocks in this world need mythril or better to be able to mine
Blocks
Crust:
Metallic Dirt
-Near Dark, has metal-like borders, but still looks like dirt
-Can onky be mined by mythril tools and above
Metallic Stone
-Same properties of the Metal Dirt, except its stone
-Slightly brighter
Rusted Dirt
-Same properties as Metallic Dirt, but with a much redder tint, and has a rust-y look
"Mantle"
Stone Alloy
-Very hard, very metal-y, can only be mined by mythril tools or higher
-Slightly brighter than Metallic Stone
Forged Stone
-Very hardy, takes 18 taps to be mined if a mythril pickaxe is used
Refined Metallic Dirt
-Metallic Dirt, but looks less dirt-y, and looks brighter
Near-Bedrock
-Full of Forged Stone
Biomes
Surface
Crater
-The rim of the crater is filled with rusted dirt, the crater itself is made out of refined metallic dirt, the middle has an acid pool in it, and its littered with nano-swarms (see below)
Bunker (2-4 per world)
-Generated Building
-Contains chests with possibly unique armor and intermedient armor
-Contains some furniture
Underground
Laboratory
-Made out of "Unobtainum Bricks".
-Filled with Laboratory based stuff, and looks like a futuristic laboratory, except in ruins
Experimental Room
-Filled with acid and skeletons
-Looks more "roomy"
Generator
-Made out of "Alloyed Unobtanium Blocks"
-Full of futuristic power plant based stuff (electric rods, fuel rods, things with rods)
Flora
Surface
Nano Trees
-Looks very metal :rock:
-Glows a faint blue light
-Looks like futuristic metal tree with blue computer lines all around it
Ironwood Trees
-Looks like a very solid grey iron pole with very solid grey rectangle leaves
Bladed Grass
-Hurts you for 2 hearts when you touch it (without armor)
Underground
Ferrum Bulbs
-Flower Bulb
-Glows a deep blue
Nano Mushrooms
-Similar properties to the nano trees, except, its a mushroom
Ironstalk Mushrooms
-Similar properties to the ironwood tree, except, its a mushroom
Fauna
H= Hostile
P= Passive
PA= Passive unless attacked
Fleshy Drone (H)
-Starts attacking if its 2 blocks away from you
-Flying mob
Terminator (H)
-Humanoid robot
Sentry (H)
-Faces either the left side or the right side only
-Attacks when you are in range (6 blocks or less)
-Stationary
Automoton (P)
-One movie: Laputa: Castle in the sky. Search it up, and add robot
-If you dont want to
Know how awesome of a movie that movie is
search it up, its basically humanoid robot with round head, curvy flat arms and legs, and a broad body
*Iron golems from minecraft are actually referenced from the same robot in the same movie
Nano-Swarm (PA)
-Looks like a metallic swarm of locusts
Ores
-Iron (A crap to- i mean, x3), Mythril(x1.5), Galvanium, Titanium, Silicium (x2)
To sum it all up:
This planet is an artifically built planet made by who knows, and was abandoned for a long time, causing its facilities to deteriorate, and nano tech freely evolve to create wild life. Since it was artificially made, it was made by extremely strong metallic alloys, and coated the whole planet. The metals deteriorated depending on its locations and environment.
Possibly a near endgame planet
