Portals (Non-Planetary)
PostWed May 17, 2017 4:34 pm
Ever wanted to go to a part of your world without having to walk all the way through? Well, this is the idea for you!
Portal Remnants
Can be obtained by scrapping a portal piece. This is done in the Tinkerers Tools
Tier 1 and 2 planets (Seth, Umbra, Alba, Thesis) gives 1 per portal piece
Tier 3 planets (Yuca, Zeno, Mykon) gives 2 per portal piece
Tier 4 planets (Cyro, Tor, Magmar, Likith) gives 3 per portal piece
Portal Crystal
This obtained by smelting Portal Remnants in the Furnace. 2 Portal Remnants is consumed for one Portal Crystal.
Portal Gem
This is obtained by Crafting 4 Portal Crystals in a diamond like shape in the Tinkerers Tools bench. Produces 1
Portal Piece
Obtained by:
Legend: G=Portal Gem M=Iron Block
G M G
M G M
G M G
Gives you one portal Piece
And lastly
Portal Activator
An item. In the crafting grid, itll be Iron Blocks with a Portal Gem in the middle
How it works:
Place the Portal Pieces in the regular set up. It wouldnt show any portal at first. Youll have to place a Portal Activator beneath it.
Once thats done, place another set in a different part of the world.
The purpose of the Portal Activator is that you can edit what portal do you enter when you use the portal. You can ofcourse, rename each portals for convience.
Well, thats it. If you have any questions, criticism, etc etc, please comment. Thanks for reading
Re: Portals (Non-Planetary)
PostWed May 17, 2017 5:47 pm
Lightbulb wrote:<b>Remnants</b>
<b>Portal Crytal</b>
<b>Portal Gem</b>
<b>Portal Piece</b>
<b>Portal Activator</b>
This forum uses BBCode, not HTML :asd: I'll fix it for you
PostWed May 17, 2017 7:52 pm
You can actually teleport to another place in a world using the existing portals.
For example on Terra:
-Place and enter Seth portal at location A
-Return to Terra
-Place and enter Seth portal at location B
-Return to Terra
You'll always return to the same portal (can't remember if it's the first or second) so you can go into one and come out the other (one direction only). Then you could set up a pair of Thetis portals to go from B to A.
PostWed May 17, 2017 9:01 pm
TwelveFoot wrote:You can actually teleport to another place in a world using the existing portals.
-Return to Terra
-Return to Terra
Its a but convuluted though. Having a clean teleporting system seems much more efficient.
museiclver
PostMon Jun 19, 2017 12:01 am
I like this idea! It'd be a quick means of darting back and forth when you're making mining trips and you don't want to run or climb all the way back up.
