[HOW TO] Uploading Pictures and Sharing Worlds
Post your awesome creations here!
PostThu Aug 29, 2013 4:35 am
Thank Minerjack for his original thread on the JJ1 forum on uploading pictures:
MinerJack wrote:Hello my fellow miners,
I know a lot of you new forum members and players want to share your oh so wonderful creations for the world to see!
Well its honestly, very easy, or hard if you don't have an email which you most likely do if your registered.
MY STEPS TO UPLOADING PICTURES
1) Go to the appstore and download "Photobucket"
2) Once finished downloading, enter the app and set up a new account. Mine is MinerJack. Real hard to guess ;)
3) Done yet? Good. Go to Junk Jack or any app or what have you.
4) Press the home and the sleep buttons at the same time. You can tell it works if the screen turns white and you hear a camera shutter noise.
5) Go to Photobucket and a word box should pop up asking if you want to upload new media. Click ok and the photos you wih to upload should have a (+) in the corner. Click upload in the upper corner and it will switch you to the Upload Media page and you'll see your pictures processing and resizing.
6) Then proceed to the My Albums tab on the bottom. Tap the photos tab towards the top to get a collection of all your photos.
7) Tap the photo you want and then the i in a bubble in the lower right hand corner. You'll get to this page:
Tap the LAST bar and it will say Copied IMG.
8) Come here to paste your picture like you normally would by holding your finger down until a bubble pops up saying paste.
9) Paste the picture(or code at the moment) and post your comment.
10) Now look at your wonderful capture of creativity! Here's mine:
Aint she perdy?
Also, the world sharing guide by Twelvefoot. This one required some editing due to some changes between how worlds are handled by JJ1 and by JJX, and one section had to be deleted until it could be revised to how Junk Jack X files are handled. I will be revising this thread, I am merely trying to make it suit the needs of most people for the moment.
TwelveFoot wrote:Everyone always asks how to upload/download worlds and I'm getting tired of typing instructions, so I'm just going to make a thread so that in the future I can just say "go here".
***Begin Lecture***
These (in blue) are the instructions to backup your JunkJack files onto your computer, you need to know how to do this before trying world sharing.
Step 0: Plug your iDevice into your computer and open iTunes.
Step 1: Click on your iDevice in the left sidebar.
Step 2: Click on the apps tab along the top.
Step 3: Scroll down to the "File Sharing" section and click on Junk Jack X.
Step 4: Select the files you want to save (hold shift to select multiple files).
Step 5: Click the "Save to..." button
Step 6: Choose a folder to save to and click "Choose" (It might not actually say "Choose" on a pc but you get the idea).
In the pic below I am saving a backup of all my files onto my computer.
Since I already have each of those files in that folder I will have to click "replace" from the annoying little popup that appears.
Now that you know how to do that and have a backup of your files
(you did backup didn't you?), you can load someone else's world onto your iDevice.
Step a: Find a suitable world that you would like to try, it will most likely be a "mediafire.com" download.
Step b: Download that onto your computer (be careful not to replace the backups you just saved)
_____________________________________________________________________________________
Step c: Go through steps 0-3 from above.
Step d: Click the "Add..." button (#5 in pic) and select the file you just downloaded.
Step e: Have fun playing someone else's world.
Now to upload your world for others to use.
Step A: Go through steps 0-6 from above.
Step B: Go to mediafire.com
Step C: Click the upload button and choose the file you want to upload.
Step D: Once your upload is complete you will be redirected to a mediafire download page, post a link to that page on the forums.
***End Lecture***
Jeez, making indepth guides is a lot of work, I'm tired now :yawn:
Hey look, most of the step numbers/letters look like faces if you turn your head sideways.
:teach: TwelveFoot
Margot1759
Re: [HOW TO] Uploading Pictures and Sharing Worlds
PostThu Aug 29, 2013 9:55 pm
:sisi:
margot
GC: Margot.1759
Noah
PostSun Sep 08, 2013 9:35 pm
Does our image host matter? I used imgur.
GC Name: Chocolate Chip Tomato
Noah wrote:Does our image host matter? I used imgur.
nope. you just need to use the direct link.
Noah
PostSun Sep 08, 2013 9:38 pm
That's a relief.
Airrie
PostSun Sep 08, 2013 11:03 pm
Do JJ1 worlds work with JJX? I'm pretty sure I did it right but it doesn't work. I don't think the guide works for both games.
MinerPeso's: 1
PostSun Sep 08, 2013 11:05 pm
Old worlds from JJ1 won't work on JJX and JJX worlds won't work on JJ1. They are coded differently. :)
Airrie
PostSun Sep 08, 2013 11:12 pm
mastery51 wrote:Old worlds from JJ1 won't work on JJX and JJX worlds won't work on JJ1. They are coded differently. :)
Got it, thanks for clearing that up :approved:
MinerPeso's: 1
JackWolv
  • Location: Trading Rare Shtuff With Other Peeps On Da Forums
PostWed Sep 18, 2013 8:21 pm
:sisi:
GC: Jackwolverine12
Check out my awesome item shop Here
"Why be a king when you can be a god?" - Eminem
oscoste
PostThu Sep 19, 2013 1:05 am
I can´t upload to my ipod downloaded worlds because in iTunes the character and worlds appear in a folder and i can´t upload on them, just outside, junk jack wont read them. How do you solve this? or is it just with my iTunes? idk wht to do, please update the guide
JUNK Frikin? JACK!
PostThu Sep 19, 2013 1:15 am
I'll see if I can get some instructions for using ifunbox up.
oscoste
PostThu Sep 19, 2013 1:29 am
Stuart98 wrote:I'll see if I can get some instructions for using ifunbox up.
Thanx man, ive been reading comments mentioning ifunbox, but dont really know how to. Thx
JUNK Frikin? JACK!
Rib
Re: ★ [HOW TO] Uploading Pictures and Sharing Worlds ★
PostWed Sep 25, 2013 1:16 am
I need some help. So when I upload the photo it's thumbnail size. :/
PROUD MEMBER OF THE PENGUIN CULT
looking to trade! :D
PostWed Sep 25, 2013 1:21 am
As soon as I have time (over the weekend perhaps?) I'll completely rewrite this post. Not only will I not be copying other people and therefore taking partial credit for their work when it isn't deserved, but I'll use more useful things that are less prone to getting borked.
xambrown
PostThu Sep 26, 2013 4:49 pm
very helpful for the newbies!
