- Location: Wishing I had my mini 1 gb ram xp laptop running arch linux
https://www.dropbox.com/photos/shared_space/xECrFyqwVf2TKba
Beginning of my 3 bit 3 number random changing password door opener... Bugs because junk jack didn't make d-flip flops work correctly... But besides that's every time I step on a panel it forwards the clocked on clock 3 locks... Basically I need to add doors so that you step... Enter number one... Set again... Enter number 2... Step again... Enter number 3... Step again... correct password very left door opens... Incorrect you will get a red light and you need to step on the left panel to reset,... Also after you step on left panel with proper passcode it locks door behind you... Th. Number checker will be designed with a simple 3 bit serial in parallel out converter as seen on bottom(if only it worked... The computer is instant and doesn't seem to forward the bit as it would with a real d flip flop... I may try building the d flipflop from logic gates since edge triggering logic gates works(i have already made both high edge and low edge s-r flip flops) and then when you go and step the 3rd time it will forward all bits and compare them with presets at the very bottom... I have not defied if I will add a number adder to randomly add bits and remove the number designator(as you can see now it shows what number you chose) or perhaps stick a number at the top telling you which password it is... Or if I will just shift it forward one memory bank Each time... Tye memory bank shifting will be very easy and can be handled with a bunch of kJ flip flops or a counter(not the one in game... A counter is a bunch of kJ flu flops in series)... I may also add a random password selector and show a the designated number at the top so I know what password it is... And LASTLY for this of you who know awesome but I wombat be sharing anytime soon... You can change the mode from creative to adventure NO CODING required.... Did you just buy a new mac with no coding tools and terminal and all pages/text edit software is not working... You can do it... Its really quite basic... Buuuut that's a story for another time
