- Location: Wishing I had my mini 1 gb ram xp laptop running arch linux
Oh yea sure sorry
P.S. ill remove this once i finish editing
P.P.S if inwas trying to increase my post count id use a post bot ;p i appologise for the super amount of posts... I didnt even realise there was a post count since i figure im probaly never going to get a large amount... I was just trying to give updates with a timestamp :p my appologies
P.P.P.S i have finished the binary to decimal converter... Which is connected to the memory and allows me to select(in sequential order... Perhaps later i will add a different type... Or random... Idk...) the next memory to compare after entering a correct password... So this way... Even if someone is watching me enter the pass... They wont be able to follow (presuming i can make the doors lock somehow XD) now i need to split up the bits from the ram using adcs... Split up the bits from the memory... Compare... If all 12 bits match... Unlock the door... And forward the memory... Oy im tired XD... Also xd Theres a TON OF Lag when the correct password is entered(none otherwise... And its only q 1/4-1/2 second lag briefly since there are so many wires XD) i should have it finished tonight i hope
i will release it in a pre ready state with all the electronics working but nothing covered up and with a manual fix to the problem i described earlier just because i would like to post it asap
after i do that i think ill tweak it and try and swich out the decimal counter with a smaller less memory intesnive one... Hopefully that will remove the lag... Although im wondering if i can use lag to my advantage... So that if someome trys to walk in when its not unlocked... A HUGE lag activates(the lag is disableing... You have to remove your finger from the screen and try and walk again after the lag passes... So the INSTANT someone walk on a platform near the door.. SUPER LAG... just enough to let them walk off the tine part of the platform they steped on... If they keep trying the lag will simply disable them for... Oh... 1 min + to get across the platform... And if i have multiple platforms... No one will even try to get across (everyone hates lag) and since it only takes a SPLIT moment to step at the edge of the plat form it also takes a SLPIT moment for them to walk off... So no apparent lag and they can walk on and off in less than a second to a second... And since they have to MINUTELY move forward(and i do mean minutely) they simply wont go forward... Not to mension that much lag may even disconect the game... So perhaps ill try that if i cant find a circuit way(such as whem the player walks to open the door a circut registers(through light or some way) and closes it and they try to open it closes... I may also use minute lag here to make it impossible to get through by forcing your way through... Or multiple doors or simply mob doors opening if you enter when its locked(kind of a security system XD)... Anyways... View my images below if you want to see my progress
! Starting to look like a circuit finnaly
Game Center ID Rose of the Risen Demon
Creations
°□°)╯︵ ┻━┻ FLIP THAT TABLE.
┻━┻ ︵ ヽ(°□°ヽ) FLIP THIS TABLE.
┻━┻ ︵ \('0')/ ︵ ┻━┻ FLIP ALL THE TABLES
Son..ಠ_ಠ
ಠ_ಠ Put.
ಠ__ಠ The tables.
ಠ___ಠ Back.
(╯°□°)╯︵ ┻━┻ NEVAAA!
Creations
- Open Spoiler
- [url]
Son..ಠ_ಠ
ಠ_ಠ Put.
ಠ__ಠ The tables.
ಠ___ಠ Back.
