My First Adventure World Base [Updated]
Post your awesome creations here!
squee420
PostTue May 02, 2017 11:52 pm
Hey guys! This is my very first build in the new Android version. I'm quite pleased with it! :)
Here is my starter build:
Here is the finished build:
And here is the mineshaft:
As you can see, it is quite different compared to my other builds.
Here is the updated version:
Let me know what you think! Suggestions and feedback are appreciated, thanks. :)
Re: My First Adventure World Base
PostWed May 03, 2017 4:00 pm
It looks nice. I like the symmetry and simplicity. Idk if it a bug or not but some of the middle carpets look bigger then the rest. Nice use of variety for the palette. Maybe in the future make a house above it? Looks good though.
squee420
PostFri May 05, 2017 3:51 am
Thanks for the feedback and suggestion! :approved:
In the future I will continue the build above ground, as you suggested. It was just easier for me to expand the build underground.
squee420
Re: My First Adventure World Base [Updated]
PostWed May 10, 2017 6:14 am
Bumping, just added the updated version, I expanded it as suggested, and added more room for my chests!
Honestly I'm not sure what to think if it.. If you have any feedback let me know!
PostWed May 10, 2017 8:16 am
Loving it, looks very well fortified & practical. Also loving the use of Library windows
Keep up the cool builds! :approved:
Users browsing this forum: No registered users and 4 guests
