Light Sensors
Report bugs and glitches here.
Molotov13
Light Sensors
PostFri May 22, 2015 11:41 am
Light sensor always output a HIGH signal even when in complete darkness, I also tried using the spanner on them and it didn't work. The electrician's tool bench isnt in the creative menu either.
[GC: SladeMolotov13]
SuperNintendo
Re: Light Sensors
PostFri May 22, 2015 12:11 pm
Yeah, Light Sensors don't work for me too.
Prediction: XsX: Thanks! Fixed. Locking. :rotfl:
On the quest of being a helpful forum user.
GC: Super_Nintendo
XsX
Re: Light Sensors
PostFri May 22, 2015 1:00 pm
I cannot fix that. :)
SuperNintendo
Re: Light Sensors
PostFri May 22, 2015 1:01 pm
Alrighty then. :sisi:
GC: Super_Nintendo
Dylan
Re: Light Sensors
PostFri May 22, 2015 2:06 pm
heheheehe, I laughed when I read that he said that...
People are Food and Slime Engulfs them.
The M.O.B Scientist
Looking for a Friend to Play With on Steam
Re: Light Sensors
PostFri May 22, 2015 2:26 pm
Light sensors, as the tooltip help states, generate an analog signal, not a digital signal. They can't directly be used without an Operational Device which is able to compare the light value with another value (for example to generate a high signal if it's below a certain value).
Dylan
Re: Light Sensors
PostFri May 22, 2015 2:28 pm
Interesting
The M.O.B Scientist
Molotov13
Re: Light Sensors
PostFri May 22, 2015 4:16 pm
I still dont understand analog signals yet :mumble:
tdgroebner17
Re: Light Sensors
PostFri May 22, 2015 6:14 pm
something clever is supposed to go here... but whatever
GameCenter: xTG17x
Re: Light Sensors
PostFri May 22, 2015 7:29 pm
So, you need a light sensor above ground to read the sun light. Then you need to put a light sensor below ground to read the light underground. Put a operational device in the center. Set the operational device to greater than symbol >.
Next, to make the underground sensor be higher than the above ground sensor you need to put a torch next to it. The Output can now be connected to as many light bulbs as you want.
Picture below shows my set up at least. Hope that helps. :)
Oh Jack if you see this may I suggest a less than output to be added to the operational devices. Not a big deal but I think it could be useful.
Re: Light Sensors
PostFri May 22, 2015 8:11 pm
To obtain a less than you just need to use a greater or equal than (>=) and place a not gate at the output :) Or you could swap the inputs instead that negating the output! Both would be equivalent to a less than
You don't need a secondary light sensor thoygh, you can do it with an analog source by configuring a fixed threshold to hook to the operational device!
Dylan
Re: Light Sensors
PostFri May 22, 2015 8:12 pm
:sisi:
The M.O.B Scientist
Re: Light Sensors
PostFri May 22, 2015 8:44 pm
A simple setup.
Place a light sensor, then some wire, a not gate, more wire, and finish with a light bulb.
The bulb will get brighter as it gets darker near the sensor. Just make sure they're far enough apart that the sensor can't see the light bulb.
SuperNintendo
Re: Light Sensors
PostFri May 22, 2015 10:30 pm
Mind-Blown
GC: Super_Nintendo
Achilles
Re: Light Sensors
PostSat May 23, 2015 11:52 am
Ive been trying to figure that out :) thx
RIP Keymaster
