[MAJOR][MY MONEY WAS STOLEN]
Report bugs and glitches here.
4zzO2020
PostSun Jan 31, 2016 12:28 pm
I wanted to buy all of the things that cost money so then I bought them and then I went into the game and nothing had changed and I thought it was just a little glitch that nothing happened so then I flicked the app up and went back in. I went on my normal world hoping it would fix itself, but it didn't so then I went into the shop and looked if it said that I had bought them but it didn't. So me being me I pressed the restore purchases button but nothing had changed. I then checked to see if I still had my iTunes credit but I didn't so the game stole my money! I checked to see if this had ever happened before but it hadn't so please give me my money back or send the items to me and please fix this problem before it happens to anyone else! :hail: :afraid:
qazedc1212
Re: [MAJOR][MY MONEY WAS STOLEN]
PostSun Jan 31, 2016 5:43 pm
That's a iTunes problem, contact iTunes Support at https://www.apple.com/ca/support/itunes/contact/
Regards, qazedc.
Find me:
YouTube | Website | Twitter
PostThu Feb 04, 2016 7:33 pm
^This is an iTunes issue.
The IAP's work perfectly fine.
You can also check your recent purchases on your itunes account. I suggest you do that.
xXtcikotciXx
PostThu Feb 04, 2016 8:42 pm
That's why you don't buy IAPs
Reason: Less swearing, more helpy.
GC: CmakLove
Noob iOS "Hacker".
Achilles
PostMon Feb 08, 2016 5:06 pm
Did you try activating them? (or redeeming depending on which iaps you got)
This is probably a stupid answer but whatever
RIP Keymaster
