Half pet half collectible?
PostTue Apr 25, 2017 8:24 pm
So I was mining in Yuca and found this thing called a slime ghost. It has the taming collar or whatever that is with the icon. But when I try to summon it nothing happens. My theory is when they converted the collectibles into pets they forgot the coding of this one thing. Thoughts?
Re: Half pet half collectible?
PostTue Apr 25, 2017 9:34 pm
This sounds like a bug so I am moving it to the bug reports section.
Is this for the android version, and what device are you using?
PostWed Apr 26, 2017 5:15 am
I am on iOS and using iPad mini 4
XsX
PostSat Dec 09, 2017 2:43 am
Fixed, thanks!
Users browsing this forum: No registered users and 0 guests
