[Android 3.1.1][Minor] Hard Dark Rock & Doors
PostMon May 01, 2017 10:47 am
Magmar's Hard Dark Rock drops both itself and Stone.
And doors can be entered without opening them if the player is moving upward like so:
p1nkbr0
Re: [Android 3.1.1][Minor] Hard Dark Rock & Doors
PostFri May 05, 2017 3:44 am
you seem to be stuck between a rock and a hard place... no? I'll see myself out through that door without even opening it
PostFri May 05, 2017 5:39 am
-throws p1nkbr0 out the window opening it either-
You should check to see if the door can be entered via dash jumps or other movements just in case.
PostFri May 05, 2017 7:15 pm
Just walking in an upward motion seems to be the only problem, dashes won't work. :)
