[iOS&Android][3.1] Simple craft grit creates iron buckets
PostWed May 10, 2017 6:02 pm
So I was crafting some grit cuz I need like 40k+ blocks for a build I'm doing anyway, I am gathering water in wood buckets and hand crafting each grit and it's taking way too long. So I put on simple craft to see if it crafts quicker (it doesn't). I go back to my inventory and somehow all my wood buckets have been turned into iron buckets.
Edited to discourage this being used for cheating
PostWed May 10, 2017 6:07 pm
Can some mod remove this.... I just realized this is probably breaking some rule somehow or something. Could be looked at as cheating. Can't figure out how to remove.
Re: [iOS&Android][3.1] Simple craft grit creates iron bucket
PostWed May 10, 2017 6:16 pm
Moved the original post to bug reports & changed it so it doesn't talk about how to exploit this. Thank you for reporting it though!
Just tried this out on Android and the same glitch is happening, when creating grit with a wood bucket of water it gives you an empty iron bucket in return instead of the empty wood bucket.
PostWed May 10, 2017 6:20 pm
I wouldn't say this is an exploit, just a bug.
But thanks for reporting it.
Steam | Discord - Multarix#3888
Black Desert (NA, UNO) | Officer of <Aggro> | Indus
