NEW DIRECT MULTIPLAYER (help to understand)
Everything about multiplayer should be discussed here.
BloodyRed
PostMon Jun 19, 2017 7:38 pm
From what I have understood the developers basically invented servers. Correct me if I'm wrong
xXtcikotciXx
Re: NEW DIRECT MULTIPLAYER (help to understand)
PostMon Jun 19, 2017 11:46 pm
just give the IP (in-game.. , not your real IP tho..) to someone who you want to play with.
GC: CmakLove
Noob iOS "Hacker".
BloodyRed
PostTue Jun 20, 2017 6:46 am
That means up to 4 players(across the world) can play with each other without having the same Internet?
xXtcikotciXx
PostTue Jun 20, 2017 12:31 pm
yep.
GC: CmakLove
Noob iOS "Hacker".
FreezyCold
PostTue Jun 20, 2017 11:25 pm
Anyone wanna play together then?
xXtcikotciXx
PostTue Jun 20, 2017 11:50 pm
just make a new thread and post your IP so people can join.
GC: CmakLove
Noob iOS "Hacker".
Brian
PostWed Jun 21, 2017 4:49 pm
My IP is 0.0.0.0 Why?
123outerme
PostWed Jun 21, 2017 9:40 pm
Brian wrote:My IP is 0.0.0.0 Why?
What platform is this? Does it consistently stay this or was it a one-time event? Are you connected to Internet? Through a router or through data?
GC: 123outerme | "If I'm not me, who's anybody?" - Me | 2nd Signature
123outerme wrote:Edit button. Top right corner. Use it.
Brian
PostWed Jun 21, 2017 11:39 pm
Android. Always maintain. Connect to internet. Data connection. Where's the problem?
123outerme
PostThu Jun 22, 2017 2:01 am
It's possible that your data connection basically makes it 0.0.0.0 so you can't try to host on data, since for Android you need to be on the same Wi-Fi as someone else. Once Android gets online play, I'm sure this will be resolved if it even was a global issue.
Brian
PostThu Jun 22, 2017 2:49 am
123outerme wrote:It's possible that your data connection basically makes it 0.0.0.0 so you can't try to host on data, since for Android you need to be on the same Wi-Fi as someone else. Once Android gets online play, I'm sure this will be resolved if it even was a global issue.
OK.Thank you very much.
Return to Multiplayer
