[2.4.4][GFX?] Invisible Underground Xeno/CRYO Plant (UPDATE)
PostThu Oct 22, 2015 6:22 pm
As stated in the title, there is a plant (grass, perhaps?) on Xeno, in the Frosted and Undurium biomes that are invisible, as "seen" :v below.
Img 1 (Onscreen)
As seen in this image, there is something on the block, thus placing the torch doesn't work until it (plant) is destroyed.
Img 2 (Super-map)
As seen in this image, the invisible plant doesn't even have a super-map sprite.
Though, I believe I remember it dropping a Big Purple Iris Sprout, so maybe it's the 1-block Purple Iris plant exclusive to the Undurium biome (though it is also found in the Frosted biome, so maybe it's actually a type of grass, or its spawn points (biomes) are incorrectly mapped?…or both? :dunno:).
______________________________________________________________
UPDATE: I went underground on Cryo and actually found a couple of invisible plants next to each other as well, which drop Aloysia Alata Sprouts, so they should be the small 1-block Aloysia Alata plant found in Cryo's Frozen Crystal biome, as shown below:
Plant 1:
Plant 2:
Someone has sumstuff somewhere and stuffs it in stuff with something…
Junk Jack for Android: OUT NOW!!!
Stuff:
Crowdin: Mudkippz
GameCenter: StevenRamos438…wait, is this still even a thing?
DragCave: aMudkip
No draggin eggz! Click on nothing…or not
hunkyducky1
Re: [2.4.4][?][GFX] Invisible Underground Xeno Plant (Grass?
PostSun Oct 25, 2015 9:40 pm
Weird haven't come across this yet @@
PostSun Nov 29, 2015 8:58 pm
*Updated original post*
Stuff:
Crowdin: Mudkippz
DragCave: aMudkip
AmazingJunkJackMan
  • Location: Universe, Virgo Supercluster, Local Group, Milky Way, Orion Arm, Solar System, Earth,
Re: [2.4.4][GFX?] Invisible Underground Xeno/CRYO Plant (UPD
PostMon Nov 30, 2015 11:54 am
Where those worlds generated before or after the gardening update?
Nothing interesting here...
PostMon Nov 30, 2015 4:28 pm
AmazingJunkJackMan wrote:Where those worlds generated before or after the gardening update?
Xeno: 2.4.4
Cryo: 2.4
Stuff:
Crowdin: Mudkippz
DragCave: aMudkip
AmazingJunkJackMan
PostMon Nov 30, 2015 5:51 pm
I had 1 invisible plant after 2.4.4 on terra but that only happened once. It dropped only a red petal.
PostTue Dec 01, 2015 3:37 pm
What surface/underground biome was it in?
Stuff:
Crowdin: Mudkippz
DragCave: aMudkip
AmazingJunkJackMan
PostTue Dec 01, 2015 7:27 pm
it was on the normal terra surface biome. in a stand alone world.
PostTue Dec 01, 2015 9:34 pm
Oh, I thought it was in the Winter biome. In which case, it'd have to be the Red Wintertulip (what is now likely a "seed flower"), but I don't know now. Wonder what it could be… :mumble:
Stuff:
Crowdin: Mudkippz
DragCave: aMudkip
XsX
PostMon Dec 07, 2015 7:21 pm
Should be fixed.
Locking, thanks!
