(2.9.1.1)(Steam) Prison Set Spear
SolarPug
PostSat Apr 30, 2016 9:40 pm
The spear uses the normal sword/maul swing movement, but does not rotate, so it doesn't properly function as a weapon. It really only hits things above + behind you when used.
Thanks, Solly.
XsX
Re: (2.9.1.1)(Steam) Prison Set Spear
PostSun May 01, 2016 5:07 pm
Fixed, thanks!
