[Major][UI](Steam) Item Disappear on Stack
LostCharacter
PostWed Sep 21, 2016 6:13 pm
If I click to split a stack and then re-add it to the stack I took it from, I lose one of those items. I managed to do it a few times and turned 7 pickaxes into 1. I can make the issue happen in the normal inventory and on the hotbar.
Re: [Major][UI](Steam) Item Disappear on Stack
PostThu Sep 22, 2016 2:51 pm
Thanks for reporting, the issues is given by the fact that durability is copied on the half stack picked up while it should remain full, it occurs only when using shift+click to split the stack. This has been fixed! Locking
