[Android 3.1.1][MAJOR][CRASH] Store Causes Crashes On Start?
PostSun Apr 23, 2017 2:09 am
After tapping on the store, my game crashed. Now the game crashed upon start. In order to play the game, I have to restart my phone. I've sent one report via Google Play, and I can send another.
I'm trying to see what the actual problem is as this is a brand new phone. I've resized the resolution to 1440p, 1080p, enabled/disabled battery saving mode.
Last edited by unfaithful p1nkbr0 on Sun Apr 23, 2017 2:38 am, edited 1 time in total.
Re: [Android 3.1.1][MAJOR] Store Causes Crashes On Start?
PostSun Apr 23, 2017 2:23 am
After reinstalling, it still crashes at verifying. Continuing to look into settings I've changed that could affect this.
Reinstalling and restarting my phone was the only way to get the game work. I started up a new adventure save, once I was satisfied with stability, I went to the store. Pressing "Restore Purchases" then sent my game into the eternal crash loop. Something's borked there...
Re: [Android 3.1.1][MAJOR][CRASH] Store Causes Crashes On St
PostSun Apr 23, 2017 11:41 am
What specific device you have? To recognize which is the offending report in Google Play console. Thanks!
PostSun Apr 23, 2017 5:45 pm
Samsung Galaxy S8
PostMon Apr 24, 2017 11:17 pm
This video is the best example I can give. It doesn't show taps, but I am pressing "restore purchases" once I enter the store screen which causes the game to crash. The game will continue to crash on start up
https://drive.google.com/file/d/0B145cJ ... p=drivesdk
(Notice the stars in the background stop moving once I press "restore purchases"
PostMon Apr 24, 2017 11:37 pm
I think I found the issue but you'll have to wait for 10017 to verify it. Let us know as soon as you'll be able when it will be available!
PostTue Apr 25, 2017 2:51 am
Seems to have fixed whatever it was. Pressing restore purchases does not bring up a dialogue, or at least attempt to. My purchases also seem to be there now. (they weren't before) Rather strange.
PostTue Apr 25, 2017 3:18 am
Restore purchase is basically useless on Android since when you ask for IAP features you also get their purchased status. They'll be already marked as bought if bought :)
So I consider it fixed!
