a hand button
This forum should be used to suggest new features or enhancements to the game
Taylor
a hand button
PostMon Oct 10, 2011 8:39 pm
does anyone else ever start building then you have to destory a block but your quick select is full and your inventory is full and you keep placing blocks on accident. so anyway i think there should be a slot just for your hand so your can click on it and your hand will be empty but you cant put any items in it.
Chaz
Re: a hand button
PostMon Oct 10, 2011 9:02 pm
Taylor wrote:does anyone else ever start building then you have to destory a block but your quick select is full and your inventory is full and you keep placing blocks on accident. so anyway i think there should be a slot just for your hand so your can click on it and your hand will be empty but you cant put any items in it.
Ah i see So the inentory row will be there but another slot that you cant put items in, its just for your hand? Smart!
Chaz
Taylor
Re: a hand button
PostMon Oct 10, 2011 9:50 pm
yes exactly!
Chocolate
Re: a hand button
PostMon Oct 10, 2011 10:01 pm
Would be helpful for sure
Nicodemus82
  • Location: Welsh/Italian guy currently living in Toronto, Canada
Re: a hand button
PostMon Oct 10, 2011 10:23 pm
that's a good idea. definitely would be helpful
Member of the Beta Tester Alliance
Twitter http://twitter.com/#!/Nicodemus82
Websitehttp://adeptgamer.com
mguniverse
Re: a hand button
PostTue Oct 11, 2011 12:10 am
I think it should let you open doors and break blocks with more items, like bamboo or the craft book. And that should behave like your hand.
Chocolate
Re: a hand button
PostTue Oct 11, 2011 12:12 am
They could add a button just below your "quick 5"
Chaz
Re: a hand button
PostTue Oct 11, 2011 1:05 am
Jackjack wrote:They could add a button just below your "quick 5"
Yes but seperate from the actual inventory so people know you cant put stuff there.
Chaz
Chocolate
Re: a hand button
PostTue Oct 11, 2011 1:23 am
It could look like a hand
Return to Gameplay Discussion
Users browsing this forum: Baidu [Spider] and 1 guest
