How do I mine iron?
This is the general forum concerning Junk Jack Retro
Jikes
How do I mine iron?
PostWed Nov 16, 2011 10:41 pm
I found an almost-black colored brick which I think is iron. I tried to mine it with stone pickaxe (which is strongest tool I get without the iron) and nothing happen.
Can anyone post a picture of an iron brick? So i know if this is the right brick.
And also, off course, how do I mine this thing?!?
Thnx
Timothy_Walker
Re: How do I mine iron?
PostWed Nov 16, 2011 10:44 pm
Why don't you post a picture of the brick, so then we can tell you what it is and how to mine it! :)
stop reading my signature!
sizle95
PostWed Nov 16, 2011 10:46 pm
Iron is randomly generated within the world, is some cases it generates in blocks breakable by gold tools only. In this case, stone tools just wont do. Sorry, but you will have to find another vein.
Credit to yeoldbacon for this signature image!
Quinck
PostWed Nov 16, 2011 11:06 pm
Usually Iron is mineable with stone, I think you may have came across silver. If you could, post the picture and we can confirm what type of block you came across.
Be sure to check out my Pixel Art made in Junk Jack here: viewtopic.php?t=929
Jikes
PostThu Nov 17, 2011 8:57 am
here are the blocks i found:
are those iron blocks?
Quinck wrote:Usually Iron is mineable with stone, I think you may have came across silver. If you could, post the picture and we can confirm what type of block you came across.
i think you confused betwin the two metals.
iv'e got LOTS of silver bars (and i'm not sure what to do with it), but not a singe iron.
gOto
PostThu Nov 17, 2011 1:42 pm
Jikes wrote:here are the blocks i found:
You need a gold pickaxe
sizle95
PostThu Nov 17, 2011 2:25 pm
Thoes are not iron. Iron spawns in all types of blocks, from dirt to blocks only minable with gold tools. Iron ore looks like any other ore, it just has different color.
Quinck
PostThu Nov 17, 2011 3:27 pm
Here I have taken two photos of Iron and Silver. You can see that clearly, Iron is much darker than the silver vein.
(Please excuse the two diamond chests I found)
Iron:
Silver:
Also, the green stuff is Mithril.
sizle95
PostThu Nov 17, 2011 3:55 pm
How do u make thoes tools!?!?!?!?
Quinck
PostThu Nov 17, 2011 3:59 pm
You craft them in the same pattern as the wood and stone tools, you just need the metal, and you have to be near an anvil to craft the metal tools.
sizle95
PostThu Nov 17, 2011 4:42 pm
Quinck wrote:You craft them in the same pattern as the wood and stone tools, you just need the metal, and you have to be near an anvil to craft the metal tools.
Thanks!!
Wolfylex
PostFri Nov 18, 2011 9:35 pm
I found a silver colored block, too. And I can't mine it with any materials, not even silver which is the strongest material I can get now.
Vide Hopper
PostThu Nov 24, 2011 5:56 pm
http://youtu.be/obozi4apA8U look at this video and you know how to craft everthing :D
Polter9
PostThu Nov 24, 2011 6:31 pm
I've encountered those dark shiny blocks pictured above (not the ones containing iron ore). I can't break them, even with a gold pickaxe. I think they function like bedrock which is unbreakable (in this version). The hardest rock that is break that I've found is Plate Rock, which there's loads of down deep and you'll need gold or mabe silver pick.
