Junk Jack FAQ - Come Here Before Asking !
PostSun May 31, 2015 5:44 pm
Hello. I am Solly, and I have put together a fancy new FAQ thread! Basically, what I will do every once in a while is go into the Help & Support section, and locate the most asked things, and post their answers here!
Yes, I do think this will help. :D
Every question will include "Key Words" so you can easily CTR+F and find it easily.
So. Let's get started, shall we?
Q: Why do people have different name colors and what do they mean?
A:
  • Dark Blue means you are a regular member, with no special privilages.
  • Pink means they beta tested the original Junk Jack at some point
  • Cyan means they are a current tester or have previously tested for Junk Jack X
  • Blue means they are currently or have previously tested for Junk Jack Steam
  • Green means they are a global moderator - They have the ability to ban/warn users, lock/unlock/merge/move/delete topics or posts as well as a few other abilities that they have used in the past to troll users (Only on special occasions or for on-going jokes)
  • Gold/ Dark Brown means they are the very special moderator Mastery51, there is a story as to why his name is this color, but that's best not to be discussed here.
  • Orange means they are an admin. Both of our admins are the 2 developers behind Junk Jack and Junk Jack X, be sure to be nice to these guys, without them, Junk Jack wouldn't exist!
Keywords: Name, color, admin, beta, developer, moderator
Q: I want to be a beta tester, how do I sign up?
A: The easiest way to answer this is that you really can't just sign up, you can express your interest and hope that Pixbits will pick you the next time that beta applications are open.
Keywords: Beta, tester, application, how, why, unfair
Q: I want to be the top poster! How many posts do I have to make to get there?
A: Well.. memberlist.php?mode=viewprofile&u=1449
Keywords: Post, count, total, top, best, awesome
Q: I accidentally deleted my world, how can I recover it?
A: Easy, just change the suffix of the .dat.bak file to .dat! There is a whole post tutorial right here.
Keywords: Backup, back, file, recover, delete, lost, world
Q: Where can I find the bottomless chest pieces?
A: Left in Terra's sand, center on Cryo's violet dirt, and right on Alba's aqua dirt.
Keywords: Bottomless, chest, piece, location, left, middle, right
Q: Do ores and chests respawn after time?
A: No. Because of world generation, it's permanent if you break a block.
Keywords: Block, ore, chest, respawn, regenerate, time
Q: Will my animals despawn?
A: If they are not tamed, yes, they will run away.
Keywords: Animal, despawn, run, tame, collar, taming
Q: Well, how do I tame animals?
A: Make a taming collar, slap them with it, make their corresponding shelter, and place them in there.
Keywords: Animal, despawn, run, tame, stay, shelter, house, taming, collar
Q: Why aren't I getting good rares?
A: You might be on peaceful or very easy, The chance of getting rare items corresponds to what difficulty you are playing on.
Keywords: Good, rare, peaceful, easy, very, hard, difficulty
Q: How can I throw items?
A: Easy, drag them out of your inventory. If you have hold-to-break off, you can hold on the screen where you want to throw your selected item.
Keywords: Throw, drag, inventory, item, screen
Q: Can I have multiple characters?
A: Of course! In the main menu, just tap the floating bubble with your player in it and select create new!
Keywords: Multiple, one, character, player, bubble, menu, new, create
Q: How can I mirror the stair tiles?
A: Craft a spanner wrench with Tinkerer's Tools, and punch the stair with it!
Keywords: Mirror, left, right, slope, stair, tile, tool
Q: How do I break the black stuff at the bottom of the world?
A: Not to correct your racism, but that black stuff is probably bedrock! You can't break it.
Keywords: Black, block, break, bedrock
Q: There's ore on the bedrock. How do I get it?
A: Unfortunately, you can't.
Keywords: Bedrock, ore, break
Q: When's the next update?
A: Whenever it comes out.
Keywords: Next, update, out
Q: A block I just broke dropped a page. What does it do?
A: You, sir, were handed a crafting recipe! Use that and it will unlock a recipe in the craftbook for you.
Keywords: Craftbook, recipe, block, break, unlock
Q: How do I switch crafting modes?
A: Go into the options, and switch it! Note that you cannot craft things you haven't found yet if you have Simple Crafting on.
Keywords: Craftbook, mode, craft, switch, option, simple, complex
Q: Help, how do I break this chest?
A: It's probably locked. You need a key with a metal equal to or higher than its lock, and to break it, you need a hammer also equal to or higher than it.
Keywords: Chest, lock, key, break, metal
Q: How (and Where) do I find portal pieces?
A: Portal pieces are found only in adventure mode, in special chests underground. Seth portal pieces are found on Terra, Thetis and Alba portal pieces on Seth, Yuca portal pieces on Alba, Xeno portal pieces on Alba and Thetis, Cryo portal pieces on Yuca, Magmar portal pieces on Xeno and Yuca, and Lilith portal pieces on Xeno.
Keywords: Find, portal, piece, where
Q: How do I make a portal?
A: You need three portal pieces. Put them on a triangular fashion and it may open.
Keywords: Make, portal, piece, triangle
Q: Why is my portal not working?
A: Portals will not work if you are on a standalone world. Make sure that there is nothing on the middle, such as a block, piece of furniture, etc.
Keywords: Working, standalone, middle, center, broke, portal, piece
That's all for now, check back later!
If you would like to suggest a FAQ, please reply below with the code filled in
Code: Select all
[size=150][b][u]Q:[/u] [/b][/size]
[i][u]A:[/u] [/i]
[size=65]Keywords: [/size]
Ex.
Code: Select all
[size=150][b][u]Q:[/u] (question goes here)[/b][/size]
[i][u]A:[/u] (answer goes here)[/i]
[size=65]Keywords: (important key words, keep singular)[/size]
Last edited by SollyStartles on Sun May 01, 2016 7:20 pm, edited 9 times in total.
Re: Junk Jack FAQ - Come Here Before Asking !
PostSun May 31, 2015 6:20 pm
Nice work. Stickied. :)
PostSun May 31, 2015 7:17 pm
Stuart98 wrote:Nice work. Stickied. :)
Thanks. :)
PostSun May 31, 2015 7:45 pm
I think the black stuff might actually be basalt.
Someone has sumstuff somewhere and stuffs it in stuff with something…
Junk Jack for Android: OUT NOW!!!
Stuff:
Crowdin: Mudkippz
GameCenter: StevenRamos438…wait, is this still even a thing?
DragCave: aMudkip
No draggin eggz! Click on nothing…or not
PostSun May 31, 2015 8:19 pm
^which you can break.
You need a key "equal" to or higher than the "lock".
PostSun May 31, 2015 8:22 pm
Mudkip45 wrote:I think the black stuff might actually be basalt.
TwelveFoot wrote:^which you can break.
Fixed, ye goons. :roll:
Zero1000
PostSun May 31, 2015 9:22 pm
Here, have Q&As:
Q: How do i make a portal?
A: You need 3 portal pieces. Put them on a triangular fashion and it may open.
Keywords: Make, Portal, Pieces, Triangular.
Q: Why is the portal not working?
A: Portals will not work if you are on standalone worlds. Make sure that there is nothing on the middle, a block, furniture, etc.
Keywords: Working, Standalone, Middle.
Former Mercenary in The Hitlist
I leave as many griefers as my name! Zero, A member of ANARCHY
«A Nice Member in Apple FanClub»
Zero1000 is a Merchant of Many
PostSun May 31, 2015 9:33 pm
Zero1000 wrote:Here, have Q&As:
Added, thanks! :)
ETA: Also made the Q text larger for better readability. :D
PostSun May 31, 2015 10:51 pm
Q: How do I find portal pieces?
Keywords: find portal pieces cant can't why where
PostSun May 31, 2015 10:56 pm
Stuart98 wrote:Q: How do I find portal pieces?
Added. :)
PostWed Jun 03, 2015 12:13 am
Less Junk Jack Specific, more forum related:
A:
Keywords: names, colors, admins, beta, developer, moderator
Keywords: beta, tester, application, how, why, unfair
lol and for giggles:
Keywords: post, count, total, top, best, awesome
Steam | Discord - Multarix#9461
Warframe | Clan Leader of <Wolfish> | Multarix
Black Desert (NA, UNO) | Officer of <Aggro> | Indus
PostWed Jun 03, 2015 10:31 am
I'll add em once I get back from school. :)
YWR
PostWed Jun 03, 2015 2:28 pm
Multipackwolf wrote:[*]Gold/ Dark Brown means they are the very special moderator Mastery51, there is a story as to why his name is this color, but that's best not to be discussed here.
Im curious now. Where can we meet up to talk about... Mastery51
Also thank goodness I read this thread or else I might end up making my mansion in a standalone world and make my portals useless..
I'm YyWR
Not money but rather, the friendships I have with others. Unity is key to victory!
PostWed Jun 03, 2015 6:13 pm
We could simply talk about it here, I was refering to the "Best not to talk about it here" in the actual FAQ post.
But I'd rather wait till Mastery turns up to talk about it, he knows the story better then anyone else :asd:
You could also simply PM him if you wanted a quicker answer.
PostThu Jun 04, 2015 2:54 am
:) well in a quick short version it all started when I was moderating the forum one day. when I hit enter to edit a post the junk jack forum's server encountered a power outage. This in turn erased my account. So my account And posts on the topics were gone but strangely many of my posts remained in the search bar but with no user name on them. Pixbits created my account again and connected my post to the new username. Pixbits than gave me a choice to chose my username color to say they were sorry for the inconvenience.
My history with junk jack includes alpha/ beta tester for original junk jack and junk jack x. I am also one of the 3 original moderators which included Chocolate, who just stopped posting one day :dunno: and tye-dye who also stopped posting.
