Android File System
squee420
Android File System
PostTue Jul 11, 2017 8:57 am
Hey, I have a few old .dat files that I need to copy onto my Android device. I just need to know where to copy the .dat files onto the device, or where the world files are stored on the Android file system. If anyone knows, can you let me know? Any info would be great, thanks!
Re: Android File System
PostTue Jul 11, 2017 9:57 am
The files are in a private folder and (to my understanding & searching) require a rooted device to access, they are found under root/data/data/com.pixbits.junkjack/files/ according to viewtopic.php?f=37&t=30702
